engine ticking noise
http://www.youtube.com/watch?v=JdS2L...eature=related
http://www.youtube.com/watch?v=xMoH_Ij7Ui0&NR=1
i replace the tct with a modded one but still making a ticking sound, sounds like its from the head area
hope its the tct, needs valve adjustment or something other that knock
doesn't sound like knock but im no expert. I would assume it was one of the valves and probably not a huge issue if taken care of. I would put a metallic object (such as a screw driver) on each of the header exhaust outlets then put your ear to the other side and see if you can tell which cylinder it is coming from. you will probably end up having to take off the the valve cover and check the valves and the gaps. If you don't feel comfortable doing it I would take it to a shop. I doubt it will be an issue if taken car of quickly but i would get on it so a valve doesn't drop into your engine or something else severe.
also, i just noticed that you don't have the header heat shield on. are those the stock headers? if not the after market headers aren't as thick to save weight. As a result you can hear the valve opening and closing much more easier. the sound doesn't actually sound that bad.
thanks for the input, i had my friend look at it and he said to try an get a valve job then go from there, isnt coming from the block
its a aftermarket header
Mintyhit
03-25-2011 09:59 AM
tenblade2001
08-21-2003 10:47 PM
