Engine Temperature at 2bar ?
Originally Posted by juniorreds,Jan 21 2006, 01:05 AM
Not for sure if this will help you out but I have the apexi I-moni that plugs into the obd2 port, well this device displays water temp directly from the ecu. When ever the water temp reaches 160 degrees or above 3 bars, anything under that registers 2 bars. I have the mugen thermostat and a majority of city driving I see 3 bars with a temp around 195 to 170, on the highway though, granted it's pretty cool here in Kansas right now I register just under 160 and have 2 bars showing at all times. Hope that helps a little.
My car is stock and does not have any cooling mod.
The weather has nothing to do with this behavior since I have owned the car for 5 years and this is the first time it exhibited this behavior.
The problem is now solved and Chris is right
It was the coolant sensor.
Thank You for all the replies
suzuka-blue-s2k
12-21-2010 07:11 PM
