Engine Still making a ticking sound after changing to Billmans
i think you're just paranoid. like others have say, the f20c is a pretty loud motor at idle. Injectors and valve can cause a light ticking noise if you're trying hard to hear it.
When I first heard about how TCTs fail, I went outside and started my car up. I hear what I thought to loud clicking and was concerned. Eventually I heard what a TCT sounds like in person and I realized that I grossly underestimated how loud the injectors are and how much louder a failed TCT is.
Originally Posted by _brandon' timestamp='1358647333' post='22278418
Try replacing the LMA's. Yours is probably making the same noise as mine is and someone on here swears he fixed it by replacing them.
i have never, ever heard or seen an S2k where the lost motion assemblies needed to be replaced...ever
Took me forever to find it but according to sto his car was making an obnoxious ticking noise and he solved the problem by replacing the LMA's. This is honestly the ONLY instance I found. I have a guy I know who works at the honda dealer try to help me figure out the noise too and he said LMAs. Everyone keeps knocking it and saying the engine is just noisey, well I have heard others who have an s2k and their engine sounds quiet at 180k miles. I have adjusted the valves countless times and even had the guy from honda do them for me to confirm. I even inspected the cylinder walls (always wanted to see) and inspect the valves. All seemed well, I used a bore scope. Anyways as soon as I get to it they are going to be replaced. Oh and I even inspected the bottom end, its fine. So I am a bit lost on what else can cause the noise. If it worked for him, might work for me. If not then oh well
PathNull
01-22-2006 11:46 AM
