Engine squeal at startup
This happens in the morning after the car has sit in the garage for 10-12 hrs and appears to happen at either warm or cold mornings.
I push the start button and the engine makes a squeaky/squeal like sound. Anybody able to provide advice on this issue?
1 Post
Remove the serpentine belt and start the engine. You probably have a pulley bearing going bad. If so, you won't have the squeal and the belt will already be off so you can check the pulleys.
If it is only making the sound at startup and goes away after couple minutes then I think it's just your drive belt is too old...
If it is the pulley bearing then it will be noisy all the time... my 2 cents...
Could be your starter as well.
Yes it only makes it at startup and it's only for a few seconds...2 to 3 secs. It goes away immediately after that and doesn't linger.
There is a startup squeel that is normal on the S. But it usually only happens when its cold out. But my car has done it in temps above 45. I believe as the starter wears it becomes more prevalent.
