Engine squeaking noise internally *VIDEO INSIDE*
Did you pull the dipstick and see if the noise stops? It sounds like you are building vaccuum and the noise is coming from the plug tube seals.
It also makes sense as this is a hot-only problem.
did you ever figure out what this was? I have the exact same problem. I started it up and pulled one plug wire off at a time, to see if the tube seal was the problem, and its not. I can hear it in the center of the motor but maybe a little more towards the intake manifold.
