Engine Shakes
Old 03-06-2008, 10:58 AM
J'sS2K's Avatar
Default Engine Shakes
This happens in reverse. I don't know if this is an issue so I ask.
One in a while, in reverse, I would slip the clutch, slightly, and the RPM drop to 500 and the engine starts to shake and revves back up to 1000. The RPM drop and shaking start after I disengage the clutch so that makes it a little unsual. Does this ever happen to anyone?
Thanks,
Jason
Old 03-06-2008, 12:47 PM
jyeung528's Avatar
give it more gas...
Old 03-06-2008, 01:38 PM
2poor2mod's Avatar
Old 03-06-2008, 01:43 PM
silvers2k01's Avatar
why give it more gas when its out of gear (neutral)? that doesnt make much sense.
Old 03-06-2008, 02:37 PM
jyeung528's Avatar
why would you say it's in neutral when the OP clearly said it's in reverse...?
Old 03-06-2008, 02:47 PM
IlleztImportz's Avatar
i have a similar problem also. when i start to go in reverse the car shakes alot and seems like it wants to stall wether i give it gas or not. (also have the clutch about half way engaged, would that be a problem?) also shakes sometimes when taking off normally in 1st...
Old 03-06-2008, 02:58 PM
jyeung528's Avatar
maybe the clutch needs to be replaced...just a guess.
Old 03-06-2008, 03:14 PM
dippin's Avatar
my car did that if i didnt let it warm up before i drove it! Let it warm up before you drive it and see if that helps!
Old 03-06-2008, 04:04 PM
^it does it even when warm...maybe diff?
Old 03-06-2008, 04:12 PM
Chagio's Avatar
scorched flywheel caused by the clutch going bad is my guess. But it's just a guess. Hopefully someone more knowledgeable can diagnose it for you.
Quick Reply: Engine Shakes
