Engine Shake after oil change.
I'm not sure what oil the previous ass monkey was using.
all i could say is, the cheap skate didnt spend the money on up keep.
so i dont know what type of oil it was using before but i switched over to castrol full synthetic 10w30.
i've never had any issues with my 00 civic sir since i was the first owner and always used castrol full syn. My sir is still in top shape after 5 years and have never given me any problem even though i redline the crap out of it.
would this engine shake go away or should i start using normal oil?
Originally Posted by RACER,Mar 10 2006, 05:52 AM
If your engine wasn't shaking before you changed your oil, well then...maybe you should run what the "ass clown" that owned the car before you used
also, full synthetic doesn't mean it's the bestest oil you can get. honestly, a good conventional oil can protect just as well, with the exception of a shorter drain interval....
Originally Posted by henesse,Mar 10 2006, 04:11 PM
I also had my valves adjusted few hours before.
could that also cause the problem?
The engine isn't going to shake any more or less just from changing between dino and synthetic.
was the work performed by you or a shop? people love joyrides. Joyriding aside, possible bad valve adjustment resulting in very bad things. Perhaps there isn't full spark for whatever reason, coilpack, etc. hope shes back soon
