Engine running too cold
So after a track day I swapped back my MY01 ECU and drove home.
The coolant temperature reported via ODB2 never went past 158 degrees.
I could turn the heat on and it felt blow dryer hot and the coolant temp dropped to 152 degrees.
My car has a 3 core aluminum radiator but normally it will reach 190 degrees no problem.
Is my t-stat stuck open? Any method to test this?
Any other ideas?
Any other ideas?
Are you getting 3 bars on the dash temp gauge ? . I had a thermostat stuck open on my s2000 and the car would not get much above 2 bars on the temp gauage, occassionally it would hit 3 bars but then it would drop back down to 2 bars. The larger aftermarket rad shouldn't affect things much in normal daily driving if the thermostat is working properly, unless you have a lower temp thermostat and rad switch.
I only got 1 bar when I drove home.
The t-stat and rad switch are OEM.
I have the modifry temp gauge fix since I run an AEM 1052 on the track however normally I see 3 bars everywhere.
In my instance I installed a Mishimoto radaitor and a large chunk of aluminum weld material washed out of the rad and lodged itself into the thermostat that prevented it from closing.
BBY2KS2K
12-22-2002 11:32 PM
