Engine redlines at 8200 even though its AP1
Old 03-20-2006, 12:43 PM
  #31
RACER's Avatar
Originally Posted by Wisconsin S2k,Mar 20 2006, 10:08 AM
The S2k is not a b16.
the dealership can't "set" the timing on the S2k ECU. It is not programmable, and can't be changed.
I think he was refurring to "valve timing" and not "ignition timing".
Old 03-20-2006, 01:00 PM
  #32
Wisconsin S2k's Avatar
touche.
Old 03-20-2006, 01:17 PM
  #33
DrDre1443's Avatar
do you have a yellow box?
Old 03-20-2006, 02:49 PM
  #34
Slows2k's Avatar
An S2k will not run if the cam timing is not correct.
Old 03-20-2006, 03:20 PM
  #35
RACER's Avatar
I guess that counts out both ignition and valve timing
Old 03-21-2006, 01:14 PM
  #36
Joe04sk's Avatar
When they rebuilt your engine due to spark plug failure, did they put new plug wires in. Bad plug wires can cause mis-fire simulating improper plug gap or faulty plugs. Take a close look at your plug wires and look for cross firing while the engine is running. Put a timing light on it and check the timing too.
Old 03-21-2006, 02:37 PM
  #37
NFRS2kSi's Avatar
maybe the timing is off??? doesn't hurt to check your timing..
Old 03-21-2006, 03:25 PM
  #38
RACER's Avatar
Read above post's.
Old 03-21-2006, 03:34 PM
  #39
Slows2k's Avatar
[QUOTE=Joe04sk,Mar 21 2006, 05:14 PM] When they rebuilt your engine due to spark plug failure, did they put new plug wires in.
Old 03-21-2006, 03:51 PM
  #40
madkimchi's Avatar
yea flashing cel means misfire/knocking. it's not a big deal if it does it once in a while but if it's keep flashing most likely you will fry you piston rings. and i wouldn't put that vortec on your car unless you have that problem COMPLETELY solved. if you add vortec it will misfire even more. and even at lower rpm. also these ecu's are VERY sensitive. when i was tuning for k20a turbo it was flashing cel but no movement in engine bay can be seen by human eyes. i had two techs and myself just gathered around the engine bay to hear and see anything but we all agreed that we couldn't tell a thing. but driver knew when it was exactly knocking.
i dunno what could cause to misfire on your motor. but i highly doubt that it's your test pipe or fuel pump.
Quick Reply: Engine redlines at 8200 even though its AP1
