Engine randomly shuts off during driving
Found it. Ended up being bad thrust washer. New motor replaced
https://www.s2ki.com/s2000/topic/113...#entry23697577
Thanks, for finding thread!
For the OP... UGH!
Same exact thing happened to me. I would be driving and BAM it would shut off. The problem was the MAP sensor. After spending a lot of money, my tuner found out that before shutting down the sensor would not see pressure and shut down the engine. You could test it with a multi meter.
Funny and scary story: I was driving on the freeway and was starting to merge on to a loop, and it shut off on me. Scary to say the least.
Good luck and hope I solved it for you.
The thrust washer thing, with that the engine locks up. It is much different from a typical stall, which involves loss of spark or fuel, where engines momentum keeps it spinning for a split second.
So I would expect the thrust washer thing to be a more abrupt stop that would be noticable. It would feel different than a normal stall.
Also, often with thrust washer upon attempt to restart, engine won't turn over, won't spin at all. Later it starts fine and everything seems fine. Its a ticking time bomb if you don't recognize what is happening. Can easily save engine if you fix it, engine will soon be toast if you don't.
Sent from my SM-G920P using IB AutoGroup
Sure hope the fuse was the problem. Heck of a lot cheaper than an engine rebuild.
So did the main relay fix it or does the problem still happen every now n then? I too am suffering the problem. I bought a new relay and still didnt fix my problem yet
Mine is doing this at higher elevations...like fuel is not getting injected at all, but I can hear the pump running at startup. It "fixes itself" after coasting back downhill.
nicholasbartleet
05-11-2009 03:53 AM
