engine problems
Old 06-16-2009, 08:13 PM
kial007's Avatar
You wont be able to run CP pistons without sleeving the block.
Old 06-16-2009, 08:39 PM
chansta's Avatar
well ur gonna have to take seperate ur tranny from ur engine first so u can get to the fly wheel etc... so i would assume taking ur engine out of the bay would be the best thing to do.
Old 06-16-2009, 09:20 PM
s2k dre's Avatar
The pistons are 87mm like an ap1!
Old 06-16-2009, 09:24 PM
Spnshfirefighter's Avatar
what kind of pistons should i buy so no sleeving is necessary if i can keep it under 1000 dollars pistons and honing with bearings ill be happy whats the best set up?
Old 06-16-2009, 09:31 PM
AusS2000's Avatar
The 2.2 is only stroked so with the 2.2L crank and aftermarket conrods designed to 2.2L specs you are ready to go. Bearing sizes depends on the markings on the block and crank (or actual measurements) and the requirements of the rods.
Old 06-16-2009, 09:33 PM
87mm je pistons with acl bearings or stock bearings? take it to a machine shop and get it honed to size of new pistons, assemble it and its good?
Old 06-16-2009, 09:39 PM
s2k dre's Avatar
U can pull the pan and replace the bearings that way but its not guaranteed that its gonna last! Thats the cheapest way.
Old 06-16-2009, 09:48 PM
since the block is apart would you recommend new pistons given i plan on turboing in the near future or are the oem confortably able to reach 350hp with no issues?
also are machine shops responsible for fabricating the rings and bearings or should i just buy atermarket ones to make the engine bulletproof i dont know which rings to buy!
Old 06-16-2009, 09:53 PM
Old 06-16-2009, 09:59 PM
AusS2000's Avatar
350!!!
Stock pistons, rings and bearings are more than up to the task.
If you were aiming for over 400 it would be advisable to lower compression and this would be a good argument for new pistons but it opens a whole new kettle of fish. Such as compatibility with FRM.
Quick Reply: engine problems
