Engine oil leak then won't start
"Btw could you do a compression test without a key ??"
Well, I guess you could insert a lever into the crank pulley and twist it really hard (and fast).
http://www.abarnyard.com/workshop/images/handcrank.jpg
Never heard of compression test without cranking engine over (with starter). Leak-down, yes. Comp test, no.
I just forgot to drop my car key off and they said they did the compression test so I was little iffy
Doesn't your key have an immobilizer chip in it? Not sure if you can bypass it, to crank engine...
Nominal compression should be (metric) 2,570 kPa or 16.0 kgf/cm^2 or 228 psi.
Don't see 120 in there anywhere. But I don't take Japanese cars to Russians. They control the computer market, of course...
-- Chuck
-- Chuck
Regardless of compression numbers, if they said they're all the same that's probably not the issue. I'm going with spun or seized bearing. Sorry but you'd probably be looking at a new motor. I'd suggest having an oil pressure gauge if you plan to turbo again. You would've seen pressure dip and known to pull over. Good luck though and I hope I'm wrong!
If the engine seized it may turn over very slowly or not at all. It prolly will not start up.
The next day of the incident I could start back up but it stalled in few min .. Seems like it stalls when it gets hot and it starts up again when it's cold
You are going to have to pull head and inspect. Sorry...
