Engine noise. different than tct IMO (vid inside)
Cheers.....Tony..
Got one because i work on an ambulance lol... going to check harder tomorrow but couldn't identify/find the exact spot of the noise due to it being inconsistent and stethoscope noise gets crazy on pulleys n belt area... but its an awesome tool and idea, i'l keep trying, appreciate the response.
At times I feel as though my car sounds similar. I think it is just noisy valvetrain. For reassurance you could do a valve adjustment. I remember driving myself nuts about a similar sound on my 05 civic... kept stethescoping until I found the source... fuel injectors lol. Totally normal.
Just keep checking around with your stethescope. When you hit the spot, you will know. If you cant seem to find it, start thinking outside the box. Note does it make the sound only on cold warm up? After a hot start?
Injectors are noisy on these that is for sure lol. That's the constant noise you hear. But the occasional...id call it a rattle/clanking which does go up with rpm is the mystery. Its at all times. Cold or hot and 95% of the time its always there. Very noticeable at idle and below 2000.
Ive noticed the same with mine.. and it bugs me.. My F20C has 122k on the clock so Im leaning towards replacing the TCT just for safety although it isnt need for replacement until it goes out. I just have a hunch the Timing chain is slapping the guides because of too much play. IDK. There are NUMEROUS vids on youtube of the same noise and questions, Im beginning to think its normal on warm up. BUT once its hot, Idk im with you on that one. I dont like it one bit
