Engine Mount replacement - disconnect steering linkage?
Old 03-08-2024, 03:35 AM
gcole's Avatar
Originally Posted by RolanTHUNDER
No need to disconnect the steering rack. You'll enjoy the results once the job is done
No kidding! Swapped them out last night and what a difference between 24 year old mounts new! Lots of little rattles and buzzes gone also, should've done this a long time ago!
The following 2 users liked this post by gcole:
RolanTHUNDER (03-10-2024), windhund116 (03-08-2024)
Old 03-10-2024, 10:47 PM
RolanTHUNDER's Avatar
Told ya so! Glad you got them done and feel the difference
BTW, look into getting an engine torque damper. I prefer the ones that fit onto your shock strut and attach to the engine hoist hole to the left of the VTEC solenoid on the head. The ETD will stiffen up the powertrain and prolong the life of your new mounts especially if they are OEM (soft rubber, liquid filled) so they don't tear as easily over time.
Old 03-11-2024, 07:00 AM
9KCanuck's Avatar
Can you recommend one? I looked into one a while ago, but it seemed like they all required cutting the stock heat shield or some kind of custom heat shield. Is that typical?
Old 03-11-2024, 08:40 AM
cosmomiller's Avatar
Received 1,753 Likes on 1,045 Posts
So my 2009 has 85K miles on it. Always garaged, never tracked even though I thought I would. All stock. I purchased new engine and transmission mounts as I thought I would replace them if and when I performed a clutch change.
Everytime I look at the engine mounts, I see no cracking or leaking of any kind. 13 years in and they appear to be just fine. I tend to think OEM is the way to go.
windhund116 (03-11-2024)
Old 03-11-2024, 08:50 AM
windhund116's Avatar
Received 1,540 Likes on 1,044 Posts
I prolly would not replace them.
Mine look clean, with no cracks or leaks, too. I'm gonna let sleeping dogs lie.
Pinky (03-11-2024)
Old 03-11-2024, 11:27 AM
Slowcrash_101's Avatar
Honestly, if you know how to heel & toe, and don't do clutch dumps, drag launches, and are smooth with the throttle, you will never tear a mount on this car.
noodels (03-11-2024)
Old 03-14-2024, 01:39 PM
BrewDay09's Avatar
The Ingalls Stiffy (later bought out by Dorman) was the top choice for the S2000, but it has been discontinued. I bought a clone version of it that was made by a member on this forum. It doesn't require cutting the heat shield.
I ran it for a little while but removed it. I have solid Spoon engine and transmission mounts and I think the combination made for too much vibration.
Old 03-14-2024, 02:11 PM
noodels's Avatar
Js racing ETD here from MBs race car =5HP
RolanTHUNDER (03-18-2024)
Old 03-14-2024, 02:34 PM
noodels's Avatar
Oh talking motor mounts i blame ^
Old 03-15-2024, 11:26 AM
engifineer's Avatar
Received 1,478 Likes on 1,106 Posts
Yeah I think the days of hard autox launches (especially in Lincoln on concrete) was what wore mine out. I was on track when they failed but it was evident they had plenty of cracks forming in them already. But those 6000 rpm launches on 255s are pretty hard on mounts !
Slowcrash_101 (03-15-2024)
Quick Reply: Engine Mount replacement - disconnect steering linkage?
