Engine Mount Install
Old 03-26-2014, 03:04 PM
Gottabfast's Avatar
Originally Posted by s2klariat
Just be sure you use the supplied bolts from Innovative. Do not reuse the factory bolts, you will crack a small piece off the inside of the girdle and the oil pump will pick it up and it will clog it. This will destroy your bottom end.
Thanks! That's a great detail to know. I got 10.9 bolts in the same sizes as the supplied bolts from innovative, but I'll definitely double check the lengths now.
I got the steel 75A hardness, so we'll see how idle vibe is with these.
Thanks for all the info!
Jwilly571
08-31-2018 05:24 AM
zappatilla
10-22-2013 04:55 AM
rikhemi
12-25-2012 06:18 AM
macr88
Engine
09-30-2011 05:48 PM
Spoolin
10-26-2006 10:34 AM
Quick Reply: Engine Mount Install
