Engine light on P0302
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-3yr.png)
if plugs and coils are good, it might be valve guides. mine (with around 50K miles) starting throwing misfire codes, and it ended up needing a valve job with new guides. have your shop do a leak-down test, which will isolate if this is it. if so, be prepared to spend > $2K or do it yourself (see my posting on DIY).
Finally, I will have some time this week to troubleshoot the engine light.
Before I start, my car is going to be 5 year old this June and its at 51xxx miles. Would this be still under warranty since it is a engine thing or dealer won't care for it?
tntrac
Originally Posted by INDYMAC,Feb 2 2011, 10:50 AM
I believe everything is 3yrs/36K miles factory warranty on the S2000, unless you purchased an extended warranty like I did (no time limit/100K miles).
I thought engine/tranny are longer. But for my case, its really hard to point directly to whats at fault for?
I had this issue and it was a cracked exhaust valve. Do a compression check. If it fails on one cylinder (number 2 in this case) do a wet compression check. (cap full of oil into problem cylinder) and see if the problem resolves itself.
If it does not, upper half problem.
If it does than it is a lower half issue.
If none of the above; keep looking...
[QUOTE=racer_X_123,Feb 2 2011, 03:57 PM] (cap full of oil into problem cylinder) and see if the problem resolves itself.
