engine light flashing, please help!!!
While I was driving on the highway, engine light keep flashing for at lease 5 times then stop, engine light away. Then I turn off the car and start again, no engine light on. I keep driving, and nothing happen again. Anyone have this happen before, please help!!!!!
![confused.gif](https://www.s2ki.com/forums/images/smilies/confused.gif)
Thank you!
![banghead.gif](https://www.s2ki.com/forums/images/smilies/banghead.gif)
Thank you!
Maintenance Required Light?
Flashes to let you know you are getting close to the scheduled maintenance.
First it flashes for only a few minutes, eventually flashing all the time. When you pass the service mileage it turns on solid.
Banned
![](https://www.s2ki.com/forums/images/s2ki/ranks/banned.png)
yea, make sure its the maintenance required light and not the check engine light. A flashing check engine light is bad so I assume if something was wrong it would probably keep doing it whereas the maintenance light does that as a reminder....
Engine light wasn't stay on.
It wasn't the maintenance light for sure, because the engine light is on the left side and the maintenance light is on the right light.
I hook up the OBDII computer tried to read code, but no code come out.
I drove my car today, but nothing happen again.
Thanks
Thanks
flashing CEL = misfire...but it would definately stay on afterwards. I had this happen to me when I had gotten some really really bad gas from a gas station (said 93 octane, but broken down in quality to probably 70 octane) and my engine misfired like crazy and blinking CEL with it staying on. I asked my friend who works as a service person at honda and he said only misfires gives a blinking CEL.
Misfiring is REALLY bad....about the worst thing that can happen to ur engine other than an over-rev.
![](https://www.s2ki.com/forums/images/s2ki/ranks/member.png)
1 Post
Can I suggest that you just check your oil/fluids/spark plugs before driving any further? If you are sure it was the CEL this little time spent might save you from bigger problems.
