engine light?
Old 11-03-2011, 12:45 AM
cesarortiz's Avatar
Default engine light?
well i just came back from a ride in my s and my engine light when on does anyone have a idea what it can be or i should check?
and another question i have flashpro can i find out from that?
my mods are only paswordjdm cold air intake and exhuast no testpipe and well yeah FLASHPRO
please help?
oh and another thing um my oil percentage life on the cluster is at 10% :/ yeah ima do service hopefully next week?
is that maybe the proplem????
Old 11-03-2011, 04:48 AM
takeshi's Avatar
As always: pull the code.
An upcoming oil change won't trigger a CEL.
From http://www.hondata.com/flashpro_s2000.html
Check and clear diagnostic codes.
Do you not have a manual or access to Google?
Old 11-03-2011, 05:17 AM
Reckon's Avatar
Are you sure it's the Check Engine Light and not the Maintenance Reminder Light? Get the CEL code checked, as stated above, to help narrow down the possible issue. You can use your FlashPro to determine the code or you can get it checked at an auto store (usually for free).
Old 11-03-2011, 06:32 AM
Switchblade's Avatar
Check the code!
Old 11-03-2011, 09:27 AM
steven975's Avatar
Since you're modded, you may want to invest in a code reader. Yea, it's free at Autozone, but you can clear them yourself with a reader, whereas a store may not be able to do that, citing legality issues.
I'm a little high-tech...I have Torque and a bluetooth reader. The bonus is that you can monitor your ECU stats on your phone, and check/clear codes, too.
Old 11-03-2011, 09:34 AM
T-Smac's Avatar
codes will clear themselves when the cpu knows the problem is gone. Clearing the codes will turn off non-continuous monitors that might take a while to turn back on. Among other things, this will keep you from passing emissions, so keep that in mind if you clear a code right before getting an emissions test.
Old 11-03-2011, 10:53 AM
cesarortiz's Avatar
i have acces to google?
Old 11-03-2011, 10:54 AM
cesarortiz's Avatar
danm thats tight
Old 11-03-2011, 08:44 PM
cesarortiz's Avatar
you guys it turned off by itself
i wonder what it was??????
Old 11-04-2011, 10:24 AM
steven975's Avatar
most likely the secondary air injection, incorrect flow code.
That thing pops up all the time.
Quick Reply: engine light?
