Engine knocking at idle only when warm
Old 02-29-2012, 04:58 PM
s2000maniac's Avatar
i think i have the "knock" too, i hear when the car is warmed up and ideling. i think its normal because there was another AP1 that was doing the same thing.
Old 02-29-2012, 05:02 PM
edogg6565's Avatar
Yea I don't know. It just really bothers me. I'm gonna pull the valve cover off and make sure a rocker isn't loose
Old 02-29-2012, 05:53 PM
trackrabbit21's Avatar
<------- gots the knock also. When im on the highway and i'm giving it about 1/4 amount of throttle i heard it, but if i go about half or more I dont hear the knocking... As for at idle, once I rev it goes away as well. but idk. its annoying tho
Old 02-29-2012, 06:03 PM
edogg6565's Avatar
I'm glad I'm not the only one then. Hopefully someone will figure out what it is
Old 02-29-2012, 06:18 PM
nissanfanatic's Avatar
Does it go away when you push the clutch in?
Old 02-29-2012, 06:35 PM
edogg6565's Avatar
Nope.
Old 03-01-2012, 07:00 AM
TougeS2k's Avatar
I hear some ticker-tack when the engine is real cold, goes away real quick.. A soundclip would go a long way
Old 03-01-2012, 07:01 AM
It could be a cracked valve retainer??
Old 03-01-2012, 07:30 AM
towingtime's Avatar
I think a good way to see if its a rod bearing is to unplug a coil pack or injector while its running to see if teh sound chages on a certain cylinder. If its a rod bearing a lot of times the knock will change or go away due to it not firing on that cylinder.
Old 03-01-2012, 07:46 AM
edogg6565's Avatar
It's not a rod knock. I've done that test and nothing happens plus it has brand new oem rod and main bearings.
Quick Reply: Engine knocking at idle only when warm
