Engine knocking at idle only when warm
I just picked up a s2000 and it seems to have a knock like rod knock, but the car runs but has the tapping sound. What could cause this besides the tct or valves out of adjustment as i have checked both of those and rebuilt the tct. I also checked for cracked retainers. I have plenty of oil and the only cel I have is for o2 sensor and knock sensor(connector is broke). The car seems to run fine other than the noise. After i adjusted the valves the noise seemed to go away but once the car warmed up it came right back. Replaced bearings with oem and spced everything to make sure i was within oem spec then torqued everyhing down. What could this be since it only does it at idle when car is warm and it seems to be 3rd or 4th cylinder area? Thanks for the help in advance.
[media]http://i865.photobucket.com/albums/ab215/edogg6565/d4d10604.mp4[/media]
Don't mean to scare, but what you are describing is typical of a rod bearing being damaged. Hopefully it doesn't get any louder, if it does, kill the engine right away to save neighboring parts.
I kind of have the same noise, repaired the TCT and did a valve adjustment this morning, and I'm still hearing a low tapping noise, and only around 2k-3k rpm. Also don't hear it when it's cold, just once its warmed up. Not sure how good my adjustment was so i'll probably do it again, but when driving and idle after 3k you don't hear the tapping as much.
Not sure if that happens with you as well.
I just picked up a s2000 and it seems to have a knock like rod knock, but the car runs but has the tapping sound.What could cause this besides the tct or valves out of adjustment as i have checked both of those and rebuilt the tct. I also checked for cracked retainers. I have plenty of oil and the only cel I have is for o2 sensor and knock sensor(connector is broke). The car seems to run fine other than the noise. After i adjusted the valves the noise seemed to go away but once the car warmed up it came right back. Replaced bearings with oem and spced everything to make sure i was within oem spec then torqued everyhing down. What could this be since it only does it at idle when car is warm? Thanks for the help in advance.
Edogg,
Out of curiosity what do you mean when you refer to "rebuilt the TCT"?
I only ask because what you are describing is textbook TCT failure imo.
--Matt
Edogg,
--Matt
