Engine knocking
#21
Originally Posted by SpitfireS,Dec 1 2009, 08:31 AM
Do you also have a CEL?
IF bearings are damaged you will most likely see a misfire CEL too.
The oil pick-up is almost in the middle of the pan, so going uphill or downhill should not make a difference.
NICE!! road btw...
NICE!! road btw...
Even with the pickup in the center of the pan a severe downhill coupled with the extream Gs from the cornering is far worse than if you just had the hard cornering alone. Just my opinion.
to taking it in under warranty.
#22
I dont think downhill would make a difference. The oil pick up is near the front, plus the forces caused by accel and braking would be more then the slope would affect it.
And yeh i dont see how it would missfire from rod knock either?
I think that its incredibly likely that ur oil was just low. Enough to not pick up through some hard corners leading to oil starvation on a big end.
You wont hear the knock for certain when your idling, you gotta give it a few revs.
#23
You may have topped it up but how much?
Im guessing you drove it back with the knocking
#24
Well good that you stopped the engine. But still i wouldnt keep my hopes up for little damage. Strange that this would happen when the sump is full but. Maybe during a long bend.
If you want to find out for sure if its a spun bearing then do the diagnostic that I said, with pulling each coil plug one by one and listening for the knock with some revs (not too high).
But if your under warranty just make sure its got oil and tow it to dealer. Dont touch anything, else your going to be up for a hefty sum of money.
#25
Why a CEL?
Well because IMO you will not just damage a rod bearing with oil starvation.
Main crankshaft bearings will be damaged too, most likely first.
If (true.. if) they are bad enough they will cause fluctuations in crankshaft speed, the ECU picks that up with the crankshaft position sensor, determines the cylinder(s) that cause the fluctuations and will tell you by showing a CEL.
Gaus > Do you get the low oil pressure warning at idle?
I take it you don't have a CEL?
Besides, going downhill at redline you might, MIGHT, have had a (slight) mechanical overrev.
The ECU can't prevent those.
edit 1: typo
edit 2 ; added thought.
edit 1: typo
#26
haha that bearing is foooked. I agree that a spun main will throw a CEL but it may not have spun one. I spun my big end on the freeway, and it still just damaged my one big end (badly). My mains were all fine. So its still possible that it wont throw a CEL if the main hasnt gone.
Still, my bearing was shaven down quite a bit, but yours looks like it exploded! lol
#27
#29
Took the engine apart. Well' I'll let the pictures do the talking.
It is from cylinder number 4 connecting rod. Both number 1 and number 4 are bearings are damaged.
This is how the clutch looks like after all the launches
Engine needs a new crankshaft and connecting rods. New parts and the labour is only $150 cheaper than a new block. So decided to go with a new block.
#30
Hey Gaus,
You said you bought the car brand new as a '07, but it looks like your engine has a Black coil pack cover. Did you put that on your self or did it come like that? I'm just worried that you weren't actually sold a "new" car.
