Engine Knock
#21
Lol yeah I know although am crossing my fingers that he is. I want this to be an inexpensive and non complicated procedure like anyone else who would be faced with this same position
#22
Just wish there was someone as knowledgeable and available to assist me as Bill as I keep hearing great things,
Good to see there are some good honest people who are willing to genuienly help in the world....keep up the good work
#23
Ok so I have received some news back from my mechanic and he tells me that I have had a melt down in cylinders 3 and 4.
Turns out that I was able to melt the tips off both spark plugs in the chambers which in turn has fallen into the piston and scored the internal of the bore. I was told that the car was starved of fuel and was running lean hence the excess temperatures being reached. I have photos of the spark plugs and of my head which I would upload in the next few days.
I am also having my mechanic look into the fuel system to check to see if the fuel pump may have a malfunction could anyone recommend where else I should be looking to prevent this happening to my new motor?
#24
sounds like the spark plugs weren't tightened to the proper specs, and were lose. I believe honda raised it from 12 lbs to 18lbs. Who ever changed the plugs previously is responsible
#29
My main concern is to figure out what caused the issue and prevent this from happening again...can someone tell me what are some causes that would make a car run lean?
Uncle Fester
09-20-2003 11:33 PM
