Engine idle problem drop when coming to stop
Old 05-28-2014, 05:38 PM
  #21
gptoyz's Avatar
Lol that is me. Yeah that is my friends ap1 that I have been after!
So far I think we are at the same point in trouble shooting
Have you eliminated vacuum leaks as a cause too
Sent from my SAMSUNG-SM-T217A using Tapatalk
Old 05-29-2014, 05:40 AM
  #22
blasphemy101's Avatar
I've looked over the all the vacuum hoses pretty closely. I found one, but it seemed to be unrelated; fixing the leak made no change in the idle problem.
Since the engine uses MAP, it shouldn't be nearly as sensitive as some cars (air-flow driven) are to vacuum leaks, with the exception of the air pump system, which is pretty simple to check.
Old 05-31-2014, 11:50 AM
  #23
Vtbbs2k's Avatar
I wish I had more time for this lol
Old 06-01-2014, 12:34 PM
  #24
Vtbbs2k's Avatar
Checked the voltage on the tps it's seems to be in the right range so that's out of the question
Old 06-03-2014, 07:35 AM
  #25
Thanks for doing that - I didn't suspect the TPS would be the problem. It would seems weird for it to fail at the very end of its range.
I was looking at my IACV over the weekend and noticed it looks like it can be clocked to different positions. I'm going to try moving it around this evening to see if it produces any changes. Again, I'm not hopeful, because (ideally) the ECU should be able to adapt the signal it sends the IACV.
I'm still thinking it might be the oxygen sensor, but there's no easy way for me to tell without a OBDII scanner.
For anyone wondering, I'm ruling out mechanical problems for the time being because the car runs fine off-idle and even idles fine with the headlights on (increased load, ECU bumps up idle). To me, everything points to idle control.
Old 06-11-2014, 03:25 PM
  #26
Vtbbs2k's Avatar
I just installed my brand new iac I'll let you know how it works
Old 06-11-2014, 04:22 PM
  #27
Please do...
Old 06-12-2014, 05:43 AM
  #28
Any news?
Old 06-12-2014, 02:39 PM
  #29
PaGEmaZt3r's Avatar
In for help. Same exact to the T problems as you guys.
Old 06-12-2014, 04:43 PM
  #30
Vtbbs2k's Avatar
I've been driving it for 2 days now and it is idling perfect only had it dip down twice possibly because it's trying to relearn the right idle. I feel like it has to be the iac because when it was at it's worse it was stalling all the time then I took off the motor on the iac like billman250 said to do because it gets notchy and the electromagnetic motor can't spin it. This solved the stalling but the idle was still fluctuating so I just decided to spend the money on a new one to see what happen now it seems to be idling great but I can't promise just yet I'm going to give it a week and see what happens
Quick Reply: Engine idle problem drop when coming to stop
