engine hesitation
engine hesitation
Since i have check my spark plugs torque i have this problem : engine hesitate between 1000rpm and 2500rpm when i try to accelerate . I have cleaned all the small connectors that goes on the thing that goes on the plug ( can't remember the english name for that !! hehehe ) but it doesn't change anything.
I thought it was bad gaz but after i fill it up it also didn't change a thing
Anyone have an idea what is the problem ?? ( It's like i have a misfire at low rpm on one cylinder ) But i'm not a specialist !! It's just a feeling i have. Thanks
[QUOTE]Originally posted by t.c.
[B]Since i have check my spark plugs torque i have this problem : engine hesitate between 1000rpm and 2500rpm when i try to accelerate . I have cleaned all the small connectors that goes on the thing that goes on the plug ( can't remember the english name for that !!
Coil !!! That was the word i was thinking of !!! Thanks ! The problem start right after the tork checked and i didn't remove the plug before the problem occured. I will change them tomorrow anyway so i'll keep you informed.
