engine ground cable help
I am finishing up an Engine swap on my ap1. I was finishing up the wiring and plumbing on the driver side today and I noticed there was 2 ground cables attached to the engine block. I know one is for the chassis ground but what about the other one? Maybe an extra cable left from the previous owner of the engine? I don't remember where this goes to. thank you in advance.
There is a rectangular block sticking out of the engine, with two small threaded holes. It goes in one of those spots.
The second spot is for a short ground cable that comes from the subframe.
Slowcrash_101 (03-13-2024)
I think they are asking what the end NOT on the block goes to.
The following 3 users liked this post by flanders:
spider2k (03-14-2024)
OH yes thank you! so after further inspection found the grounding point you mentioned but found a ground already attached. After following it I found the other end tucked under the brake booster. So I'm assuming that end goes to the block where the other loose strap is? also I appreciate all the help! thank you guys.
The following 3 users liked this post by Stvrn6:
The following 3 users liked this post by DocDrizzler:
Mr.Matchbox
06-22-2018 07:54 PM
