engine flush
engine flush
Hi everyone....i was wondering if anyone could recommend and engine treatment that will flush the sludge from my motor and clean it up. I see many productss at the stores but am not sure what to get or if any or that good. Any suggestions??
It's all the same stuff, petroleum distillates.
What makes you think you need to do this? Did you pull the valve cover or oil pan to inspect? If you've been using good quality oil and changing regularly, there is no need for a motor oil flush treatment.
I would recommend and actually use Auto-Rx on my vehicles for engine cleaning:
http://auto-rx.com/
For carbon buildup I would recommend BG fuel system products...professionally if you think you have a serious problem.
http://auto-rx.com/
If you've been using a good oil and maintaining it well you likely don't need anything, but something like auto-fx like Indy recommended is a great product to use for safe gentle cleaning. I would not use any of the stronger kerosene based stuff you buy over the counter. The good thing about auto-rx is t he cleaning that is done on the piston ring landings, which can keep the piston rings working as intended, many times they can get stuck due to deposits. Auto-rx is available online and it requires a bit of a process but it is the only thing I would use on this vehicle.
One other approach is to run some short intervals on high mileage oils which tend to be good at cleaning.
http://auto-rx.com/
http://auto-rx.com/
where can i buy the auto-rx? i looked on thier site and its seems like a solid product. id like to use it on my next oil change.
