engine fire -> damaged harness
Last weekend, I had an oil leak while driving on the highway. This resulted in an engine fire that caused damaged to the harness that connects the VTEC solenoid to the engine:
My first question is. If I were to order the parts to replace it, does it have to be the whole ENGINE WIRE HARNESS (illustration 1 on the pic below)?
As you can tell from the first picture, the wire still exist, but it's missing all the insulation. Is there other alternatives besides purchasing a complete harness? I'm not so handy with a soldering iron. But, is there any way I can tape this up to heatproof this?
Any input would be greatly appreciated. THANK YOU!
Unfortunately, Slows2k is correct. Either pony up for a complete harness or have yours repaired. Considering the price for a new one, I'd at least attempt a repair before laying out the $$.
Soldering iron, wire of the correct gauge, solder, wire loom, good electrical tape.
Originally Posted by Billman250,Jan 30 2007, 06:48 PM
If you were a paid member, I'd sell you the part of the harness you need.
Guys, I have another issue. the engine oil leak inside the header (inside the heatshield). I took it to a detail shop to clean the engine including the heatshield. Yet, it is still fuming!
I checked the dipstick, no oil leak. Temperature gauge is normal. No check-engine light. The gas consumption is normal. The fume is definitely coming from the manifolds. Should I be worried? What do you think about me letting the car run idle for an hour?
Originally Posted by Slows2k,Jan 31 2007, 05:45 PM
It's most likely residual oil burning off.. I'd assume the oil filter leaked and oil went everywhere & caught fire. It's not gonna be an easy clean up getting all the oil cleaned off.
