Engine fire!
Old 05-14-2006, 07:22 AM
Saffron's Avatar
Thanks for your help everyone. I think I'll try to remove the heat shield and get right on the headers. Thats were all the smoke seems to be coming from.
Old 06-11-2007, 02:18 PM
CKit's Avatar
That sux.
Old 06-11-2007, 03:43 PM
milkbubble's Avatar
Originally Posted by Slows2k,May 14 2006, 09:58 AM
Brake cleaner works great for removing oil, make sure you get non-chlorinated cleaner, it works better.
Simple Green or Greased Lightning degreaser also works well to clean under the hood after you blast away the oil with brake cleaner. Leave the engine running, and spray everything under hood, then use a "misting" rinse with a hose.
Take care not to spray H20 in the alternator, under the ignition coil cover, or directly at electrical connectors.
Fram filters are very well known for having the gasket stick.
In addition.. I use aluminum foil to cover my alternator when I clean my engine. You can shape it around the alternator and it wont melt.
Old 06-11-2007, 08:55 PM
Eluded's Avatar
Originally Posted by Saffron,May 13 2006, 03:28 PM
We popped the hood to check how things were and BAM! there was a nice little fire going on on the cover of the headers. We quickly sprayed it off and he sat with a gaping mouth as shown here:
wow
Hope everything is ok with the car.
Old 06-11-2007, 10:03 PM
R3DS2K's Avatar
once u finishes cleaning.. check for any burned wires.. or harness.. cuz it might ground out if they are burned
Old 06-12-2007, 07:41 AM
robodeath's Avatar
When he changed the filter, he didn't notice that the old filter's gasket (what do you know, it's fram!) was still on the filter screw.
This happened to me when I had my supercharged civic. Scared the **** outa me when I started my car and oil spewed out everywhere!
andrewewing
11-13-2008 12:25 PM
bkmagby
11-26-2006 07:06 AM
counselor
09-26-2006 11:06 AM
Triple-H
10-26-2004 06:08 PM
Quick Reply: Engine fire!
