Engine feels like stalling.....need helpo dudes
Sup every1 i got a prob n i dont really wanna pay a mechanic to take a look at it so im gonna c if u guys know wats up... almost everytime i turn on my s2k it feels like its going to stall out when i didnt even do anything, clutch in and everythin! Then if i push the acclerator in to about 1K and let off, or just barely tap the acc, it makes that "about to stall out sound" grrrraaaahhhhh haha idk how to put it into words but yeah....all this started after i installed my K&N FIPK so yeah im prtty sure it has to do somethin with that... i aint too mechanical knowledgeable so try not to make me feel THAT stupid lol sooo yeah thanks dudes...
I can't remember if this works on the S2000 or not but a lot of ECUs will do an "auto tune" when temperatures fluctuate.
Reset the ECU (do a search) and fire it up, let it idle for 10-20 minutes and then shut it down. I'm sure others can clarify if this works or not but you should have reset the ECU after you put on the K&N.
I know on my Triumph (I know, it's a bike not a car), it's called a 12-minute tune, you fire it up, don't touch the throttle and 12 minutes after the cooling fan kicks on, it's done adjusting itself.
First check your install again if you did it yourself. I still have the stock airbox on my car, but have seen some CAI that have a vacuum tube running to it that may be routed wrong or loose etc.
As above check IAC motor and clean if needed (I believe there is a sticky in the faq section for this).
Also check the MAP sensor, try the "map whack" and zip trying methods first (though I think the symptoms are different for those) and if in doubt replace it.
-good luck
-good luck
Wisconsin S2k
03-25-2017 12:55 PM
amartin
08-27-2001 10:12 AM
