Engine Failed - Swarf and Broken Bearing found in Sump
S2000, Registered Year 2008, 51k
Swarf and broken bits of bearing found in sump
Engine Failed - Bearing gave way?
Crank is off .32
Piston rods scored
Engine replacement required.
Comments appreciated
Crank is off .32
Piston rods scored
Why did you change your post that much?
The original one had a lot more text.
You say - in the original post - you checked oil regularly.
Even with a full sump you can starve the engine from oil if you pull enough G's for a long enough time.
On a long sweeping on/off ramp I think you could get into that situation.
Or in other curved sections you know well and know how to take them at high speed.
So.. what tires are you using?
Sporty alignment?
Just because you are 100% sure the oil level was ok does not mean you are safe from oil starvation.
You mentioned before the engine is apart.
Did the dealer check the oil pump on output specs etc?
Sporty alignment?
SuzukaBlueAP1
05-14-2002 10:58 PM
