Engine Damper
Engine Damper
I'd like to find out from those who have them... what is the main benefit from using this? I know what it supposed to do, but I'd like to hear any impressions from the owners and a little about the installation if you don't mind. Is this something you can notice or is it one of those "makes you feel good having one" type of item?
The damper does its intended job, after the install the side to side movement of the engine has definitely been dampened. The engine is still allowed to rock in the mounts, but not as easily as before. Some of the vibration through the shifter is reduced, and I can't say that I've missed an upshift after installing. You do have to disconnect the damper to remove the transmission though.
Check this thread for more info regarding fitment issues:
https://www.s2ki.com/forums/index.php?showt...46182&hl=damper
Damn Slow, it looks like it's not an easy fit without making something like your custom bracket (btw, it looks really nice).
I wonder why J'sAP1's install was easier...
The 00-01 cars seem to have lower AC lines than the 02's. Vapors2k who originally prototyped it for a LHD car didn't have near the issuses I did. Vapors, dms2k, and J'sAP1 all had 01 cars versus my 02.
I'll take the glass window and crappy J's damper fitment though.
worth all penny for this stuff for a sc car
Very noticeable difference! Think the S2k has a great tranny? IMO, shifting is 100% smoother with the engine damper.
Watch your shift lever while you drive around (CAREFULLY!) and notice how much it bounces around, reflecting the movements of the engine and tranny. The engine damper reduces and slows the movements of the engine and tranny, and reduces the lateral torque movement of the engine that occurs when revving/bliping the throttle.
The engine damper also has a noticeably positive effect on the handling. Shifting through corners, and cornering over rough surfaces is definitely improved.
There are some fitment issues (at least with an '02), but installation is not difficult at all. Just make sure you have the proper wrench to reach the rear (#4) bolt on the OEM heatshield.
The OEM header heatshield won't fit with the J's heatshield. Don't run without a header heatshield or there will be a HUGE increase in the engine compartment temperature!! I made and installed a custom header heatshield in about 10 minutes using sheet aluminum, with many layers of aluminum foil behind it, and it works amazingly well.
Good luck!
-Pete
Good luck!
-Pete
http://www.jsracing.co.jp/
just released the LHD kit
I hope more ppl will enjoy this mod as much as I have.
The gear shift vibration has significantly improved.
I used to missed 3rd gears one in a rare while. This prob costed me a couple of 1/10 of a sec at the drag. I have not miss third gear since and mind you I have a lot more power than what I used to have prior.
