Engine Dampener In
Engine Dampener In
I installed my engine dampener in the car over the weekend. The hardest part of the whole install was the heat shield, that 4th bolt is a b*tch to get at! Anyways once I got the shield off I am in no hurry to put it back on. Anyone see a problem with driving with it off?
Well i beg to differ... have you personally driven a car without a dampener and then with?
I can tell you without a doubt it made a difference. The gear changes are crisper and the acceleration on tip in is improved. Vibration of the stick in the car has been reduced in amplitude quite a bit. Now just driving around normal, no not much of a noticeable difference, but when on the loud pedal rowing gears, it's better and I know that for a fact...
So it seems the consensus is the shield should stay, by the two sarcastic comments. Easy enough to modify and put back in. I'll added that to the list of things to do when I do brake/rotor/and line swap in March...
Whatever I didn't ask people's opinion on the modification just on if the heat shield is a needed component.
I know it made a difference, whether you chose to believe me or not is your choice....
the car came with the heat shield, both on the stock header and to block the battery & a/c lines, etc... it's clear there is a heat issue that honda felt was necessary to warrant their existence. it should be kept if possible.
Originally Posted by drewmob,Feb 22 2010, 12:27 PM
the real question is: is the etd needed? i'd say not as much as the heat shield...
no, seriously. you wasted your money. use search, find the truth...
As you know, I put the Innovative Mounts in recently, haven't had a chance to drive it since then though. I will say this - my passenger side mount was nearly ripped in two and the driver side mount was completely ripped.
I have no doubt this was why I was having issues shifting 1-2 at high rpms.
The Engine Torque Damper is a bandaid over bad engine mounts...
