Engine Coolant Change
In the helms manual step 4 states to remove the drain bolt from the right side of the cylinder block. im not sure where this bolt is. I checked everywhere and im not sure which bolt they are talking about. Can anyone help me locate this bolt or if you can put a picture of the bolt. thanks
I always found that to be such a difficult bolt to remove that I left it in place on this engine. It's in an odd spot and on a very tight angle. I've drained the fluid a couple times and always got out pretty much the entire amount of coolant without removing that bolt. I wasn't concerned about any small amount of fluid that could have been left in the engine as it couldn't have been very much. Not having to remove the bolt was worth it to me. The fluid that has come out of my engine has always been very clean.
Norccer
08-01-2018 01:08 PM
darcyw
10-08-2017 06:49 AM
