Engine Bogging?
Engine Bogging?
Ok, I was sending my sister to school and when I was stopping and going over the speed bumps my car seem like it was bogging and wouldn't pick up. I've only had this car for a month with 93,xxx miles. It did this two times while clutch-roll-clutch-roll- and then gas. Later down the road I WOT and it seemed fine with Vtec and all. I was just wondering if this is normal or what is it?
Map sensor - You could try the "map whack" to clear it up.
Dirty Throttle body - Get some intake cleaner and a rag to wipe off the throttle body.
Heat soak - Not much you can do for that. Lower temp thermostat, fan switch, and higher pressure radiator cap.
ok, imma try the map whack and see if it help. This problem is not consistant. Only heavy stop and go and thats only sometimes too, but red lights with clutch balancing is fine.
Originally Posted by philipminge,Oct 28 2010, 04:18 PM
fill me in for the aussie bloke. lol
map whack.... whats that involve.... my car has this on occation also.
cheers
cheers
Originally Posted by spa01s2k,Oct 28 2010, 12:17 PM
I use to have this issue in my car too. Was very inconsistant. After the map whack it seemed to have cleared up a little. But the problem hasn't occured since putting in Mugen Thermostat, fan switch and radiator cap.
tlogic
11-06-2009 11:03 AM
NJTom2000
11-18-2003 02:59 PM
