Engine block question
Do you guys know if the block and main cap "girdle" or main cap piece is matched together by numbers or something?
Or possible to mix and match between engines?
The other engines I´ve seen using this design can´t use a block from engine A and girdle from engine B without killing the crank.
The reason is that the main journals are bored out or honed with the girdle in place and only create a perfect round hole when used together.
I hope you understand, not sure I used the right words.
The girdle and block are machined together as a pair and cannot be transferred between engines without having to line bore the main journals.
I would only line bore if there is minimal difference in alignment between the two halves when assembled.
I´m buying a block and want to be 110% sure is the right girdle, that´s why I´m asking.
Originally Posted by B5254T4,Nov 18 2010, 09:35 PM
Hmmm... Hard for the engine builders if they have many engines in pieces.
classicvin
04-07-2016 04:41 AM
tkm_dave
08-31-2014 11:30 AM
