Emission Check
Emission Check
I have an 07 AP2 running stock equivalent tune from Hondata Flash pro. The reason for running the stock tune is because my 2nd o2 (cat) sensor stopped working , so I just turned it off in the flashpro and ran the stock equivalent tune. I have looked around on s2ki and did everything Iv read. ... A few short drives... a few long drives.. cruise control set to 60mph for 3 min on the highway... This all over the last 4 days so It does have cold starts and Iv also done many on/off starts and stops , all over about 300 miles.
Why do I still have 4 incomplete parameters????
Well right off the bat if your looking to pass inspection your gonna have to put a new secondary o2 sensor in and enable it so it can run its cycle, that will be your cat monitor and oxygen sensor test readiness.
as for your evap, idk why but for some reason it is very hard to set, did you read your owners manual and follow all the steps in it to set readiness.
anyone else wanna chime in ?
i just passed deq last week and have been having issues with a CEL. i read many things on here about needing to follow specific steps for the car to go through a full duty cycle etc etc. well my CEL wouldnt stay off long enough, so i said what the hell, i went to the deq test center with a scanner, cleared the CEL 2 blocks away and drove in. my evap said it was still not ready but i still passed, and i highly doubt the car went through the different parameters that everyone said it needed to. however my o2 is working and i dont think i could of gotten away with disabling it.
i know some states allow 1 of the readiness systems "not ready" and you still can pass
Replace the o2.
The reason your monitors are not ready is likely because they are resetting every time you turn the car off. Likely the way you have it set (turned off)
wowwitsgau
10-12-2015 09:00 PM
