Eliminatin Torque Steer?
Old 04-07-2021, 08:01 AM
  #31
Rewire's Avatar
Originally Posted by Jub
You have a toe difference of .07 degrees per side in the rear. Not saying that is necessarily your issue but that is more variance than I'd be happy with.
I have heard that even minor toe variance can be detrimental to handling. Do you think that even a variance this small would be detectable?
Old 04-07-2021, 08:25 AM
  #32
Car Analogy's Avatar
Received 1,439 Likes on 1,071 Posts
Originally Posted by Rewire
I have the same tires on my Model S and 120+ mph still feels fine and stable. That was actually why I went for them for the S2000.
I know it's a different car and the Model S is more expensive and new tech, but the S2000 feels more.....floaty. Like it's not gliding over the small bumps and such in the road, it's all getting transferred to the chassis. That's why I was wondering if I could do for some suspension upgrading.... The grip feels fine, it's the way the body rolls and doesn't feel fully planted to the ground.
I'm just not convinced it's something to do with the tires. I mean, DWS 06 were developed specifically for all-season use on sports cars and exotics.
This is precisely what my whole post was about. The same tires on another car might work great, yet on this car same tires can be spooky.
Its got nothing to do with traction, its all about sidewall stiffness. This car is extremely sensitive to tires and alignment.
You can't use experience of how tires work on other cars as a guide to how they'll work on this car.
Old 04-07-2021, 08:42 AM
  #33
TsukubaCody's Avatar
You have no clue where I'm driving my cars.
Get out of here if you're not going to help, troll.
You’re not driving a tesla or s2000 on all seasons on track, so yes, I do know where you’re driving.
you’ve been given a lot of potential culprits and washed them away with ‘but mah tesla’
Old 04-07-2021, 09:03 AM
  #34
Site Moderator
Super Moderator
sam_spider's Avatar
Received 2,863 Likes on 2,075 Posts
Enough. You've made your point.
rpg51 (04-07-2021)
Old 04-07-2021, 09:31 AM
  #35
Jub
Jub's Avatar
.07 degrees is not an insignificant amount. Think about a rear steering vehicle, be it a tractor, fork lift, etc. Rear toe has a very significant effect. I don't want to open this can of worms, as it exists in many threads on this forum BUT some people will recommend .1 degree total toe in for the rear. I am not of that camp but will avoid that argument here as it's not really the point.
Personally, I am very specific about my alignment settings and you will not see my S aligned by a "Firestone" or "insert generic tire store here". Mine goes to shops that offer track car prep and is aligned to nearly the exact specs I ask. I do have a .02 degree variance on my latest alignment which is not noticeable. Firestone and the like generally look for "green" and the spec on the S2k is wide. Green means it is within tolerance of the spec but not precise. When I first got my AP2 (after having an AP1) from the "normie" previous owner, I had to cross my fingers it wasn't messed up because it just felt off. I was used to my AP1 with very specific alignment settings and extreme summer tires. The AP2 was on good Michelin all seasons with a decent "green" alignment but drove like crap. It wasn't darty or scary but it was not precise. That being said, I wasn't doing 105+ in it either. Add alignment and extreme summers and it drove like a champ.
Old 04-07-2021, 05:50 PM
  #36
Billman250's Avatar
Received 1,398 Likes on 837 Posts
Rewire, increase your front to to +.05 each side, for a total of .10+
See how your stability is.
Old 04-07-2021, 09:06 PM
  #37
Rewire's Avatar
I will try that, have the wheels re-balanced, and ask that my rear toe be identical or close to.
Thanks all.
Old 04-08-2021, 05:06 AM
  #38
Mr.Matchbox's Avatar
Get a set of 16" wheels and buy real dedicated good winter tires. (Nokian for Example)
Use the wheels you have and fit proper high performance sport tyres.
Switch the wheel sets in spring and autumn.
Problem solved.
stewpitt
Member S2000 Classifieds and For Sale
04-30-2019 03:48 PM
Tehk
03-14-2016 07:31 PM
s2000ellier
R&C Parts For Sale
01-08-2016 04:46 AM
Jake89
10-09-2015 03:52 AM
Quick Reply: Eliminatin Torque Steer?
