EDFC turning
Old 12-22-2006, 05:13 AM
YuriArts's Avatar
Originally Posted by buzilanga,Dec 21 2006, 04:35 PM
My question on this is, i am about to install my edfc, should I take my shocks of my car, lift the car up and install it? So I wont have any pressure on the shock?
No, for installing the EDFC you don't have to remove the shocks. Just follow the instructions and your set.
I'm also installing them right now and have the same problem with the turning. To counter this you have to stiffen the shocks enough.
Apparently TEIN has some sort of brackets for other cars so the EDFC won't turn, but not for the S2000.
Old 12-24-2006, 03:32 PM
buzilanga's Avatar
I only have a question, when I install the motor on the shock as it is indicated by the manual itself, when I finish the last 2 full revolutions, then screw the motor, when I want to try to screw it counterclockwise it wont go, so I screw it about 1.5 clockwise, the motor wobles again, so I screw the motor and then it becomes all tight. When you do the 1 turn clock and counterclockwise, does it go full? Does it go more then 1? And also when you installed the motor, did it go all the way in?
Hope I'm explaining it as good as possible.
YuriArts hoe is met jouw instalatie gegaan?
Old 04-03-2007, 10:14 AM
r_duff's Avatar
TTT! has anyone found a solution?
Old 04-04-2007, 03:31 PM
r_duff's Avatar
Old 04-04-2007, 06:06 PM
Banned
Initial D God Hand WannaBEE's Avatar
can you use the edfc while the car is in motion or only when it is still?
Old 08-10-2007, 08:46 PM
rainorshine's Avatar
Still looking for a fix... my front left edfc motor spins... all the others are fine. Do they make a bracket for the S2000 yet? This is obnoxious...
rsxiness03
04-26-2010 10:19 AM
face
04-12-2010 11:39 PM
r_duff
51
10-07-2009 04:22 PM
r_duff
08-10-2007 08:34 PM
Trip
06-15-2005 12:15 PM
Quick Reply: EDFC turning
