ECU location on a European Car
Banned
As the title says, can anyone tell me where the ECU is and what's the best way to get to it.
Remember I sit on the righthand side
Behind the triangular shaped panel by the passenger's left foot. The edge of the panel goes part up the the door opening, and has a piece that goes behind the door seal. If you're going to remove the ECU itself, you'll probably have 'fun' with the bolts. They have a 'rounded triangle' type head that you need a Honda tool for, or a bit of ingenuity.
-Brian.
-Brian.
-Brian.
-Brian.
Banned
Thanks BM,
I've had the panel off and that's when I counldn't go any further due to the triangle bolt thingy. Does Honda sell this type of tool to the public?
If not what would you use, a large pair of grips?
Originally posted by Subaru2000
I was hoping that I could get the bolt off without any damage, so Honda will never know I've messed about with a Vafc in case of any problems.
Bugger
Bugger
-Brian.
