Easy way to the ISB ?
Can anyone help me out with replacing my isb, let me know.
Right now im on the 32mm case bolt, then the snap ring, can i remove the bell housing with the tranny on its rear side up?
Originally Posted by R1_Pilot,Jul 8 2010, 08:45 PM
Input shaft B?? ... bearing? ...
When you want help you need to provide info ... you are not helping yourself with acronynims like that.
J
J
I went through the manual, could not find a 32mm nut anywhere, there is a 27mm though.
If you are doing what I think you are doing, this is a major undertaking. There is a bearing on the mainshaft ... you basically need to remove all the transmission guts.
J
J
