E-Manage and 550cc installed, but i have still some questions!
Old 05-31-2004, 01:55 PM
  #21
S2000_Europe's Avatar
have you check that you have the AFM set at 0?
check the information that has been exported to main unit is set to 0
Old 05-31-2004, 02:10 PM
  #22
Salaska's Avatar
Yes it is at 0. On my last drive i even deactivated all maps excluding BC which is set at 2.9v.
Old 05-31-2004, 02:18 PM
  #23
Thomas seems that we are alone in this forum
I asume that you are runnig the stock fuel pressure regulator nad you have reseted the ECU
at ilde you should run 14.7
Regards
Old 05-31-2004, 02:19 PM
  #24
Salaska's Avatar
Yeah it seems so
Yes, i run the stock FPR and reseted the ECU. At idle the ecu compensates to 14.7.
Old 05-31-2004, 02:22 PM
  #25
Well,
I do not know what else could be.
Wesmaster should chime here he is the master with the emanage
Old 06-03-2004, 06:33 AM
  #26
Salaska's Avatar
Hi,
i have a question about the injector correction function. My car
runs to lean during the whole rpm's. But at a flat curve.
Now i was thinking to add some fuel with injector correction
function. In other words uses a 1.1 or more corrections. If i am
right that this will cause the e-manage to enrichen the fuel?
BTW: Of course with stock injectors and with the 550cc!
Old 06-03-2004, 06:53 AM
  #27
injector correction, is measured by milesecons, high number means more time the injector keeps open. That should be a work for your tuner. I would recomend you to "play with the AFF and use the iteration funtion.
Old 06-03-2004, 07:01 AM
  #28
Salaska's Avatar
It seems my tuner has no time during the next 5 weeks
So i switched back to stock injectors and comptech fmu and looking for a easy solution to just raise the fuel during the whole rpm band, because i have a very flat a/f curve which is to lean
Old 06-03-2004, 07:34 AM
  #29
you are in the same situation as me.
I will sugest you do not pass 5000 rpm and never WOT, 50% maximum at 5000 rpm and you will not have any problem and you car is safe.
I got SX FRP once I got the fuel pressure gauge will try to tune the car an see the A/F is going.
Juan
Old 06-03-2004, 09:19 AM
  #30
Salaska's Avatar
First step to the success
I added some fuel on the injector map: 0 at lowest and 10 on highest and interpolate it.
Now when i hit the gas and accelerate i have an A/F Rate from 13.0:1 - 13.5:1 and my car seems to got stronger.
I will add some more fuel and hopefully will be soon at the 12.0:1 - 12.5:1 range
Quick Reply: E-Manage and 550cc installed, but i have still some questions!
