E-Manage and 550cc installed, but i have still some questions!
Because i let all settings to 0, it is running lean at idle (14.5:1 - 14.7:1).
I once added some fuel and the wideband goes down to 12.7:1. I done some driving with map trace than and on the position when it goes from the richer setting to the 0 setting it bogs.
I guess is should add more fuel, right?
I will phone with a tuner tomorrow, which have some e-manage experience. Hopefully he can help me out and tunning my car, because its more difficult as i thought (i am a newbie in such things)
Ohh one thing wonders me too:
After the car stands some time, fully cooled down and i turn the key to "On" i sometime hear a loud pop from the engine bay!
But after i start the car no CEL and it idles really good. What could this loud pop-sound be?
It seems i have found the problem!
The base injector size of 360 was to big. I switched down to 290 and the car idles crappy and was way to lean. So i switched to 330cc as base injector size. Now i noticed no bogging even after a longer testdrive.
I accelerated my car very carefully and stayed under 4000k rpm.
My wideband showed numbers from 13.8:1 - 15.7:1, but its hard to point the correct numbers out, because it seems the stock ecu try to compensate it.
The pop-sound which comes up, when my car stands longer and i turn the ignition on (not starting the car) is still there. Maybe its because my car was running very rich before and some fuel detonated?
BTW: Could it be also possible that the PLX M-300 is not calibrated correctly and shows leaner numbers as they real are?
Questions over questions, but at the moment this board is my only help
Originally posted by S2000_Europe
PLX is self calibrated
I do not remember a pop sound when started the engine
According to martucci stock injectors flows 380 cc at 42 psi
At the moment it is most important that i can drive my car to the tuner (120 km away)
