E-Brake light stays on
Old 11-19-2005, 06:32 PM
StinkyTofu's Avatar
Default E-Brake light stays on
I just went to the track yesterday and now my brake light always stays on when i'm driving. Is this an electrical problem or something that has to do with my brake fluid? Anyhelp would be appreciated, thanks.
Old 11-19-2005, 07:30 PM
Slows2k's Avatar
Check the brake fluid level 1st. It's possible the switch in the master cylinder reservoir has gone bad. Unfortunately, the entire master cylinder must be replaced as the reservoir and switch are not available seperately.
If the fluid level is OK, and the e-brake is down unplug the switch on the reservoir. If the light goes out, the switch is faulty.
Old 11-19-2005, 08:10 PM
StinkyTofu's Avatar
Thanks alot, that is great information. I'm gonna go check right now
Old 11-20-2005, 09:39 AM
StinkyTofu's Avatar
Just wanted to give you guys an update. The brake fluid level was low when i checked...so i filled it up to the max line and now my problem is fixed. Thanks again SlowS2k .
S2k4mee
04-07-2012 01:44 PM
kerm1t
01-24-2012 06:40 AM
KJ1225
10-11-2006 04:52 AM
ideugene
11-20-2005 11:32 PM
S2000AD
07-19-2004 03:49 PM
Quick Reply: E-Brake light stays on
