Dyno of Toda Pistons and Cams
I'm a puss, someone else is going to have to be the first to install the pistons/cams and show the dyno. I've already bought most of a turbo kit, just need intercooler and piping now. Thanks for all the insight guys.
Adam
Adam
Originally posted by BenR
regular gas and 13:1 is fine so long as you make the effort to reduce physical det producing areas in the CC.
but hwat do you mean by: is fine so long as you make the effort to reduce physical det producing areas in the CC
Originally posted by Asura
I would also be curious in regards to how Toda plans to warranty their parts on said engine.
When you're tearing apart an engine and installing high compression pistons & aggressive cams, there's a fairly high probability that something is going to go wrong if you don't have an excellent installer and tuner. It would be difficult for Toda to provide a warranty to every schmuck that tries to just drop the parts in and then ends up grenading their engine.
SC_Highlander
02-24-2012 04:29 AM
Requiem
08-17-2010 12:11 AM
