how many miles on the car i beleive the average is 188-208, now its always good to dyno the car when stock this way you get a better feeling on how your mods are coming along.
Dynolab in Marietta GA is where I went, They use a Dynojet Dyno. I had 6800 miles on the car, I had just drove from Montgomery AL to Marietta approx 150 miles. Coolant temp 196F
IAT 125-102F measured on a honda PGM-FI tester. IAT dropped to 102 at the end of each run. PCM reset was done before all runs. Unfortunately, No baseline runs.
Slows2k, thanks for shareing. I have almost the same set-up as you except I'm running the Mugen CAI and Mugen header. I was considering swapping my Mugen for the Toda, but your results has me thinking. What would your results equate to on a dynojet like UL's? Or will the #'s be the same?
UL dynoed me at 215 with no mods on an '01. He says the difference btw dynojets and his dynapack is on the order of 5-10 hp depending on conditions. If you dynoed with him before stay with him. Also helps to do a baseline.
