dyno result
Old 03-19-2005, 02:26 PM
vampire's Avatar
Default dyno result
hi guys..
my car was running great with the 4IG CAI and the fantastic 63mm T1R exhaust system with T1R test pipe
last Saturday i decided to go to the dyno (DynoJet) for tuning the Apexi S-AFC2 purchased used from my friend
in the 1st run got 208whp and after the tune with the S-AFC2 this peak value didn't change while i did a change in the air/fuel ratio only in 8000rpm+
but what u'll see in the dyno chart is a great gain from 6000-7000rpm ?! `
any comments are appreciated
THANKS `
Old 03-19-2005, 03:35 PM
MaxGeek's Avatar
Could you make the dyno chart a little bigger? Also if you use gif format instead of jpeg it won't be as blurry.
Old 03-20-2005, 04:49 AM
vampire's Avatar
i'll post a bigger chart once i go home
Old 03-20-2005, 03:16 PM
persianafied's Avatar
nice gains ... good luck with your car
Old 03-20-2005, 03:19 PM
S2KANDRE's Avatar
nice
Old 03-20-2005, 03:32 PM
shivers's Avatar
Peak numbers don't mean a thing. Increasing "area under the curve" is where it's at and that's what you've done. I'll take a car with great area under the curve vs. peak any day of the week. You're a/f ratio looks pretty smooth too. Good job!!
Old 03-21-2005, 09:06 AM
Former Sponsor
Shadow_S2K's Avatar
Why are the lines so choppy? All the graph's that I've seen had pretty smooth curves.
Old 03-22-2005, 05:04 AM
vampire's Avatar
but guys,, why the increase in the 6000-7000rpm range while i left the stock a/f ratio at these points ??! `
Old 03-22-2005, 08:46 AM
Banned
vivids2000's Avatar
looks good but there is still more tuning in there.
you need to drop your vtec X-over to the 54-5800range
also need to add a little more fuel at 6k
what do your plugs look like? are you detonating at all?
Old 03-22-2005, 08:58 AM
youngjun91's Avatar
How do you do that? I'd love to do that to my MY04. This would be exactly what I think all MY04's need. What components would be involved.
Thanks!
Edit, nevermind, I think I found the answer. It sounds like VAFC.
Quick Reply: dyno result
