Dumb Question...Sorry but need advise
Ok here is the deal. I have the CV Joint Shimmy and also the Clicking. Had the clicking first then 2 days ago the Shimmy started out of the blue. I already know the fix (42320-s2a-310) for the Shimmy and the clicking is the Spindle Nut needing to be replaced.
Now the DUMB part. I called around and can get the PN above from Honda for $315 for just the Inner CV Joint Driver Side. I tried Kragens and they have a CV Half Shaft for $115. That sounded cheap so I questioned if it was what I needed. They guy said yes as it has both the Axle and the Inner/Outer CVs installed as one part. He says one side goes into the Spindle and the other to the Diff.
So will the Half Shaft include the CV joint as he says? If so I will order both the drive side and passanger side and be done with it. Fixing the Spindle Nut in the process.
If it does not, then please forgive my ignorance. I'm a computer guy, not a mechanic
i have yet to see a half/axle shaft sold without the cv joints.
so unless someone else states otherwise, go ahead and order it. the counter guy did tell you it comes with it. so if it by some chance it doesnt come with the cv joints, you can just refuse to buy it cause he lied to you.
pantyraider
06-27-2005 01:21 PM
