DTC jump failed, car dont start up,Need help pleas
Old 01-09-2011, 11:28 AM
harrison1990's Avatar
Default DTC jump failed, car dont start up,Need help pleas
Hello guys,
Have tried to jump the DTC to clear my ABS and EPS light today, but stupidly plugged the paperclip into the wrong wire and now cant start the car up.
My suspect is a blew fuse but i have no idea which fuse it is and dont know if I blew some other things.....
Please give me some help guys!
Many thanks!!
Update:
This is the two pins that i have shorted
http://img209.imageshack.us/i/img0895ro.jpg/
Hello....it is the #46 fuse under the hood that blew...!Thank you!!thanks very much guys!!
Old 01-09-2011, 11:46 AM
japhethwar's Avatar
Guy I hope for your sake you only blew a fuse, never under any circumstances jump anything. If you have a warning light take the car to a reputable mechanic and have it checked. Check all of the fuses there is a detailed list in your owners manual. Good luck
Old 01-09-2011, 12:44 PM
Hello thanks for reply
I hope i have only blew a fuse, the worse thing I can think of may be the ECU, as long as i didnt blow the engine.....
I have diagnosed by myself, but just cant do it.....
Old 01-09-2011, 01:19 PM
SgtB's Avatar
Check the ECM fuse under the dash. You probably shorted it to 12v instead of ground.
Old 01-09-2011, 03:51 PM
Hello thanks for reply!
ECM is it the same as the ECU fuse?
I have just checked that fuse but nothing......did i just blew my ECU??
is there anything thatt i can check?
Old 01-09-2011, 04:34 PM
99SH's Avatar
Let's start with this.... Which two pins did you accidentally short?
Old 01-10-2011, 03:25 AM
im not sure what the pins call, but i only knew the colour of the wire, my S is a RHD, so the wiring in the connector may be different, i will try to post a pic and show you which two i have shorted.......as i remember the first one have a Brown wire connected in it....
Old 01-10-2011, 04:19 AM
Got the image uploaded that will show the pins that i have shorted
http://img209.imageshack.us/f/img0895ro.jpg/
Many thanks
Old 01-11-2011, 02:54 AM
Really...on one know the answer??
Old 01-11-2011, 03:47 AM
Billman250's Avatar
Received 1,401 Likes on 839 Posts
does the CEL come on with the key on? The CEL is not only good for codes, it checks the state of the ECU power.
Quick Reply: DTC jump failed, car dont start up,Need help pleas
