DROPPED SOMETHING INTO MY TRANNY!
Old 03-19-2009, 06:41 PM
fatjoe10's Avatar
ok, how about draining all the fluid, somehow tilt the car towards the drain fill plug side, and then use a coat hanger on the lower hole to fish for it? I guess you could jack up the left side of the car and put the wheels on cinder blocks, then jack up the right side higher.. that way you still have clearance to get under there....
Old 03-19-2009, 06:52 PM
liquid_helix136's Avatar
little different, and off topic, but i dropped a small screwdriver into my engine bay about half a year ago and it was never seen again, i was parked in a driveway and it didnt fall thru, i ran over speed bumps in a sub division to try to knock it out and everything, looked around for it for an hour. Never found it
Old 03-19-2009, 07:02 PM
oyitzpreston's Avatar
i tried all of that earlier but imma see if i can try compressed air to push it out hopefully. im gettin it towed to a shop and hes suppose to pull it out for 400 if he cant get it out another way
Old 03-19-2009, 07:19 PM
haywoodjablome's Avatar
We have known since early 2002 that the S2000 transmission has an oil pump, when cmnsnse tore his apart to modify the oil pick up and concluded that Honda should have made it a bit longer. It was he, who advised a slight overfill of fluid if you didn't want to do the pick up tube mod.
https://www.s2ki.com/forums/index.ph...pic=49224&st=0
That oil pump? Um ................ that would be part #2 ....................
http://www.slhondaparts.com/browse.asp?Mod...&ViewParts=true
If that little plastic thing got chewed up and got sucked into the pump, kiss your tranny bye-bye.
Old 03-19-2009, 08:48 PM
damn good thing i didnt do that i actually thought about it
Old 03-19-2009, 08:49 PM
Old 03-19-2009, 09:14 PM
Dancer's Avatar
It's a long shot but how about compressed air in the filler hole and a shop vac at the drain hole? Or if you think the cap is closer to the filler hole try it the opposite way.
Old 03-19-2009, 09:42 PM
Blue_AP2's Avatar
this sucks i almost did something like this to my integra i had a while back
Old 03-19-2009, 10:40 PM
1cem4n's Avatar
I used to work on my friend's cars all the time and we'd always lose and find tools in the engine bay... Best thing we found was an entire breaker bar...
Old 03-20-2009, 05:50 AM
GPW AP2's Avatar
If you end up pulling the tranny you may want to think about doing the clutch while you have it out.
John
Quick Reply: DROPPED SOMETHING INTO MY TRANNY!
