Driving with no passenger seat
I've got most of my interior out right now except for the driver's seat and safety equipment (roll hoops, belts). The SRS light is on because the passenger seat isn't plugged in.
Is it safe to drive like this, or will this adversely affect the operation of any of the safety features, should the unthinkable happen?
Your driving and you are in the driver seat, you are fine. Many people take out the passenger seat for many reasons and put it back when they can or want to.
The light being on will not effect anything.
As long as you are seated in the driver's side of the car, you are still protected by your seatbelt, but the question remains: will the driver's side SRS equipment (air bag and belt pre-tensioners) operate properly if the system detects a fault with one passenger side element?
Also note that once the SRS fault code is set, it will not clear without you following a special procedure. There is a special tool to make clearing the code easier, but some have done so without it. Do a search for a description of the re-setting procedure.
its safe as long as you dont have anyone seat in the passenger side lol.. but like coraldoc said.. will the driver side SRS work if the light is on even if its for the passenger side.. im sure the belt pre tensioner will but air bags.. i ono..
Thanks for the heads up on the reset procedure, as well.
Originally Posted by Hockey,Aug 4 2008, 03:53 PM
The passenger's seat doesn't plug in on my MY00. Are you saying yours does????
Hmmmmm
-Hockey
Hmmmmm
-Hockey
